- Replacement Carburetor for KLR 250
- Bogging under load
- Has Anyone Fitted a Mikuni TM33 to Your KLR250?
- '91 KLR 250 Trouble Shifting from 1st to 2nd gear
- '91 KLR250 Stator Wire Repair
- Klr 250 needs to have choke on for it to run all the time.
- Which feeler gauge?
- 1994 Kawasaki klr 250 D
- Wider front tire?
- No start
- New battery, no power
- Gas tank question
- mikuni Carb specs/ settings
- new carb settings
- KLR 250 fork mounting holes
- KL250-D2 D3 swingarm question
- KLR250 too rich?
- Finding a gremlin in the engine
- Progressive Fork Springs?
- 2005 KLR250 Kickstart stuck issue
- Alternate plastics to fit '90 KLR 250?
- New to me 1987 KLR250
- Klx230
- 2004 Kickstart tear down
- newbie project
- Need a shock
- KLX250s bogging down above 7000 rpm
- New KLX250: Pinched Innertube
- High Altitude Jetting
- 250 wont Bang once even w ether, hav spark
- Weak Spark
- Electric Start KLR 250
- Hard Starting KLR250
- KLX 240s alternator output
- KLR 250 Motor Question
- 1988 KLR 250 fuel tank gasket
- klr250 will not start
- KLR250 not starting - faulty KACR
- Changing Speedometer from KPH to MPH 2014 KLX250s
- 99 klr 150 1700 miles clacking sound!!!
- I am restoring KLR250 from Japan
- KLR 250 - bad valve train?
- Wondering what parts are interchangeable between models
- I'm back!
- 2001 Super Sherpa Value?
- Fuel Line
- Klr 250. plugged up runs normal?
- klr 250 valve stem oil seals
- 1996 KLR250 (KL250d) Decal Dimensions
- Has anyone got a 250 shock for sale ?
- Fitted lowering links but have a problem
- Hi all, just purchased a 1995 KLR250
- Engine pollution removal
- more hp and torque ?
- GM coil for KLR 250?
- Parts interchange
- KLR post accident reconstruction PLEASE HELP!!!
- Hello, new guy with a stupid question about needing rear fairing
- Sprockets
- Homemade side racks
- Help with Clutch cover/Clutch push rod on 1995 KLR 250
- rejoining crankcases
- exhaust header
- KLR 250 Disassembly
- Hotwire a klr 250
- 04 KLR 250 Trouble shooting?
- How to Disable KACR?
- '86 KLR 250 No Compression - Options?
- 2001 KLR250 Oil in stator cover
- 2003 KLR 250 Value $1700
- KLX 250 Part Out
- KLR 250 Starting Help Please
- Hard cold starting problems
- HELP please,ive just bought a stolen recovered 1985 klr 250
- KLX250S Saddle Options?
- looking for seat or cover
- KLR 250 mods?
- 1980 kl250 rebuild/top speed performance
- Need valve adjustment specs '04 KLR250
- klx250s question
- Just relocated to Glendora, CA (SoCal)
- washable air filter
- Air filtration, carburetion, and a few general engine questions
- Front sprocket - 2 versions - washer
- 1980 KL250 Cylinder base gasket??
- I need some suggestions about my problem
- KLR250 Fork oil amount
- Break In Period
- Vintage Resto Q
- Fix or replace: bitch to (kick) start
- '06 klx250 bits for sale
- Trail Restrictions?????
- After market Carb Super Sherpa
- klr 250 1989
- bike will not stay on low idle after carb clean
- some quick questions on a klr250
- 2007 klx250s
- No Rear Brakes
- Cam chain question cont.
- Cam chain noise
- 1984 klr250 strange problem
- 1984 klr rev problems.
- 2007 KLX250s
- No Battery
- Plans
- Selling - How much to ask?
- New To Forums
- burning oil
- Rate your exhaust here!
- 1995 KLR250...Is the chain a 520 or 420 ?
- Upgrads And Opinions On '87 KLR
- hard starting on new bike
- x
- Tappet clearance
- 96 KLR 250 for sale
- KLR 250 in Brisbane
- KLR 250 Problem
- KLR 250 accelerate/clutch problem
- Kaw250 or Yam225?
- klr 250 engine
- 86? klr 250 chain tension
- FS: '97 KLR 250 Front Fender/Super Moto
- KLR 250 Air Filter Replacement
- Why the KLR in CA.?
- KLR 250
- super sherpa
- New KLR 250 Owner with Questions?
- Rear rack question, need quick reply
- cam/timing chain
- 86 KLR electrical issues
- Luggage Rack
- '86 KLR 250
- 100 mile range
- hot cams?
- klr 250 wont start
- newbi needs help...what oil filters fit the klr250
- Is this forum dead or what?
- My klr 250
- KLR250 forums
- Risers
- Performance mods and gas mileage
- Engine stripdown
- Rack for KLR250
- KLR250 Production
- Why a KLR250?
- HELP! Engine cuts out
- Another one of my insane ideas
- KLR250 questions
- KLR 250 pic
- KLR 250 performance
- KLR250 ignition fault
- Need help upgrading my 05 klr 250
- Looking to upgrade my 05 KLR 250
- I NEED HELP TWEAKING MY 05 KLR 250
- New KLR250 Owner here...
