Klx250/300 how to get all the fuel out the Acerbis tank.
Old Apr 27, 2008 | 09:07 PM
Martindktm's Avatar
Default Klx250/300 how to get all the fuel out the Acerbis tank.
So I did a write up here: http://www.advrider.com/forums/showt...02#post6856102
Happy reading.
Martin
Old Apr 27, 2008 | 09:23 PM
QuiteThumper's Avatar
Default RE: Klx250/300 how to get all the fuel out the Acerbis tank.
Martin, is Your pulse feed line for the pump, between the carb and the motor?
Old Apr 27, 2008 | 10:33 PM
Martindktm's Avatar
No its on the carburator. When you remove the smog crap your left with a nipple on the front of the carb. Thats where I hook it. I will probably change the pump model for one that is used 4 stroke atv's or a 640 Adventure. As I explain im not sure the 2 strokes pump is the best...I could hook it to the crankase vent but I did the vent modification so I will amost have no pumping effect if I do that. So I will need a 4 stroke pump to optimize the system.
Old May 10, 2008 | 11:27 PM
Gany's Avatar
Hey Martin, any updates as to how the pump went? was there enough vacuum off the carby etc?
Old May 15, 2008 | 11:36 AM
Martindktm's Avatar
The actual pump is not good. Its design for big pulse from the up and down motion ofa 2 strokes pistons since its normally connected to the base. I have a 4 strokes atv vaccum pump on order that is design to run in the intake vaccuum. Ill let you know how it works.
Old May 16, 2008 | 11:09 AM
Martindktm's Avatar
So I got my new pump yesterday night and installed it. Now works like a charm. I end up installing an Actic-Cat Atv mikuni pump Arctic-Cat part number 0470-758. Its design for the 4 stroke intake vaccuum source.
Old May 22, 2008 | 11:41 AM
Martindktm's Avatar
FOr the one who wants to know...I did test the range yesterday on the road. I had put road tires on it with a winshieldand did a 535 miles (700 kilometer) trip yesterday. I did 165 miles (266 kilo) before engine stall. Then switched to the reseve and went on road back back again for another 48 miles (77 kilo) befor getting to a dead stop. I had bring some spare fuel to refuel...So I did a total of 213 miles (343 kilo) on a tank. Speed was steady at 68-74 mph (110-120km/h) at 6000-6500 rpm. Bike has a 300 barrel with wiseco piston, fmf Q4 with power bomb, n1tc, 132 main, 35 pilot.
Old Jun 10, 2008 | 07:27 AM
tremor38's Avatar
Just a brief thread jack...what are you using for a windshield?
I'm considering this model made by MRA for when I do my touring. It's only available in smoke or clear now, but the KLX250s is one of the bikes it's supposed to fit.
ORIGINAL: Martindktm
Old Jun 12, 2008 | 02:32 AM
tremor38's Avatar
Bump!
Old Jun 12, 2008 | 02:17 PM
Martindktm's Avatar
Here's a link to the winshield model that im using. Its the spitfire clear model.
http://www.50highwaycycle.com/windshield.htm
