View Poll Results: A poll
Red base black post
0%
Voters: 12. You may not vote on this poll
What 2 colors should I powder coat my rims?
RE: What 2 colors should I powder coat my rims?
See the thing with the red is I have red LE RIMS now that I still have to get rebalanced. Hopefully that is the issue with them and not the fact that they are bent. Also going to rotate the tire. If not I am going to have expensive paper weights.
That is the plan I am going to have my friend balance them. Also I am going to have him move the tire where it is sitting heavy to the valve stem side. If not I will powdercoat them with a black lip and green center and sell them to ya. J/K
you should look into getting a set up like speed has for balencing wheels and checking run out. i made one because i have a bent rim off a 636 that i was told was ok and hell no. that thing was definitly tweaked in the slightest of ways. only way i know the le rims are not bent is because they arenew and i havent hit anything with them on my bike in the 300 miles i put on them.
consider a wheel set up so you can check the rims after you powder coat them.
ORIGINAL: mikedrinfla
