Spark Plug issue
Spark Plug issue
I have an bayou 220 kawasaki 2 wheel drive fourwheeler and i can't figure out why but it uses the spark plugs up in about 3 days if i put another one in it will fire right up but it will need another one in another three days......Any help is thankful!!!
It looks like it is running rich! Check to see that the choke is disengaging when you take it off choke. I had a Boyou 220 and the carburator fuel bowl vent line, ( clear plastic hose ), was routed back and by the exhaust pipe. It melted and sealed closed, which made the motor run like crap, and it fouled plugs as well, so check that before you go farther!
OK I am new....I had to join to get answers before I go bald from pulling out my hair. I have an 86 kawasaki bayou. I have all new electric componenets. Cdi,coil,rectifier and so on. The problem I am having is that I have power to the coil. Bought a tester light. When I turn it over I believe its the green wire gives me the blinking light. Other one stays on(when power is on). I hook them up to the coil and use the tester light lights up But doesn't blink thus not giving me any spark. I have tried to switch them and same problem. Please for the sake of my hair help! Thanks
Jord, welcome to the forums. I'm not sure on your Bayou. Just be careful swapping wires, especially between coil and black boxes. Don't want you to inadvertantly toast something....
I'm pretty sure there's a link or some help we can offer. Maybe Dragone can point you to the "manuals" section, if you don't own one.
Glad to have you with us.
