Need help picking a Kawasaki Ride
Welcome, Dur. As mentioned^, several things to consider when choosing a ride. What kind of riding do you want to do? Any experience with bikes? Give us more details and you'll get plenty of free advice!
Welcome, again.
Welcome, again.
If you want a bike that can do a bit of everything without necessarily being the best at anything (and you're average height or above) then a KLR650 is a good choice. If you want to ride exclusively on dirt or road, or if you have "duck's disease" (*** built too close to the ground), then there are better choices in every direction, but the KLR is a great "do-everything" type machine.
I should mention that the KLX250 has exactly the same seat height as a KLR650 (890mm, the KLX has more ground clearance though), so except for the difference in weight if you can ride one you should be able to handle the other.
OK... I'm also trying to figure out what to get - was looking at the KX or the KR... I'm 5'8" and 240 lbs... are these going to be too high for me? Or will my weight push them down to earth? lol How about when I get down to 200? I'm working on that right now...
My inseam is 30" btw - if that helps...
csaba1589
03-29-2010 02:18 AM
