I have a problem
I have a problem
I have a 2000 ZX9, i'm having problems with it cuting out in 3rd gear, and up. It was running fine then it rained and was left out. Is it possible that any sencers are bad any other help would is most welcome.
RE: I have a problem
Did you read the forum rules???? hmm, pwi can request your ride..... hahah, ok, messin'
Have you checked out your molex connectors, cleaned and reattached?
Welcome to the forums.
Sounds like a moisture problem. +1 on Dragone; check your connectors. You may also want (need) to take tank off to view airbox and top of motor to see if you have water accumulated in any vital spots. Leave the bike out in the sun to see if it helps dry out. (Temps in southern Ohio have been in the mid 90's; shouldn't take too long to evaporate.) Rule out moisture, then let us know.
shawn_460
07-15-2005 07:24 PM
