2000 zx9r problems
Old 03-05-2007, 06:51 PM
iceman's Avatar
Default 2000 zx9r problems
Hey guys, has anyone seen this before...my bike has been doing some strange things...1st when my bike is in first gear kickstand down and key on, when I squeeze the clutch the bike starts without me push the start button. Also when in neutral when I turn the key to the on position the bike startsup without me even pushing the start button. It's kind of scary...whats going on?
Old 03-05-2007, 07:04 PM
dieselmech's Avatar
Default RE: 2000 zx9r problems
check your wiring harness for pinch point, it sounds to me that the starter botton is shorted out, which could be the wiring or the button itself. You can do a continuity test if you have a wiring schematic. You can do onefor thebutton too,disconnectyour battery, disconnect the starter button from the wiring harness, use a multimeter and put a lead oneach terminal for the starter button, see if you have continuity with the button released, then pushed in. That should tell you if your button is ok.
Old 03-05-2007, 07:38 PM
welcome to KF
Old 03-05-2007, 08:17 PM
iceman's Avatar
thanks...
Old 03-06-2007, 02:57 AM
iceman's Avatar
Bought a timing advance for my zx9r..is installing it a good idea? do they help improve the bike proformance?
Old 03-06-2007, 05:50 AM
ORIGINAL: iceman
wow, that is some crazy story. As mentioned above, time to check out that electrical gremlin for sure. As far as the advancer goes, I never played with them.
Old 03-06-2007, 07:15 AM
srobak's Avatar
if you need a schematic of the wiring let me know... I can scan it and post it up.
Old 03-06-2007, 07:42 PM
iceman's Avatar
Yes, I need a diagram, it would help me alot...this problem happen all of a sudden.
Old 03-06-2007, 10:27 PM
srobak's Avatar
Ok... PM me your email address.
Old 03-06-2007, 10:33 PM
iceman's Avatar
ronsmart1@yahoo.com
Quick Reply: 2000 zx9r problems
