To change the oil or not to change?
Old 04-17-2006, 06:30 AM
Red636guy's Avatar
Default To change the oil or not to change?
I bought my '03 Ninja last spring. Changed the oil using Amsoil and a K&N filter. I only put about 350 miles on it last year so my question is, should I still change the oil this spring or would it be ok to leave whats in there since I didnt run it much? I started it up a few times this winter but only a handful. So not sure if by sitting the oil would go bad. Obviously Amsoil isnty cheap but my top concern is the bike and its performance. Thanks!
Old 04-17-2006, 07:03 AM
50 Slider's Avatar
Default RE: To change the oil or not to change?
I'm sure that you'll get different opinions from each person you ask, but I would change it out. If your bike has been sitting in storage for while and the cold temps, it could start to break down and you won't get as much protection as you would from a fresh change. Besides, it's only $$$$$$
Old 04-17-2006, 09:01 PM
ryninger's Avatar
oil change 40bucks give or take....engine rebuild thousands.... I know what road I would ride down...
Old 04-17-2006, 09:39 PM
Green_05_636's Avatar
Change it, I change my Very often no matter what.
Old 04-17-2006, 10:04 PM
txredneckmedic's Avatar
if you have to ask...do it
Old 04-17-2006, 10:06 PM
gotrice's Avatar
+1
Old 04-18-2006, 04:16 AM
BigRig18Wheeler's Avatar
If you change oil every 3000 miles, then a good rule of thumb is every 3000 miles or every 3 months.... 2000 miles every 2 months.....etc, etc..... I would change it...
Old 04-18-2006, 08:12 AM
lemac's Avatar
Change it bro.........
Old 04-18-2006, 02:27 PM
speedracer138's Avatar
How many total miles on the bike and are you going to use Synthetic or Petroleum based oil?
Old 04-24-2006, 09:46 AM
Red636guy's Avatar
Total miles on bike....6600.....I used Amsoil sythetic last time and intend to use it again.
Quick Reply: To change the oil or not to change?
