Tachometer light is fading
Old Oct 11, 2006 | 11:02 PM
MARX255's Avatar
Default Tachometer light is fading
I have a problem with my tach. It is dark on the left half. Is it a loose cable? I will poke around after I get home from work but would love to have an idea what to look for.
Thanks
Old Oct 12, 2006 | 08:46 AM
markmeinteil's Avatar
Default RE: Tachometer light is fading
You just have a burnt out bulb, unless the circuit board has a break in it. If it's the bulb, (and it probably is) that's a cheap fix.
Old Oct 12, 2006 | 10:39 AM
calamarichris's Avatar
+1 what Mark said.
Kinda frustrating to remove the fairing, remove the dash assembly from the front subframe, THEN remove the backing from the dash to get at the tiny little $3.00 bulb. But for some strange reason, your uniformly-lit speedometer assembly will look more beautiful than it ever has after you've gone through all this trouble.
Good luck.
-CCinC
Old Oct 12, 2006 | 11:37 AM
Jodub's Avatar
Put LEDs in if you can. Red would look good, except for the whole redline thing. I'm sure you'll figure something out.
Thot
Sep 15, 2012 03:33 PM
crazyfromabove
Aug 19, 2012 03:54 PM
sz_danii
Aug 8, 2011 05:45 AM
klrjr
Jun 2, 2008 06:24 AM
spin003
Nov 22, 2007 04:17 AM
