98 ninja 250
98 ninja 250
I have replaced piston heads and ring and I have timing set cleaned the carb and it's still not cranking I have a spark and fuel almost feels like air is coming out of the air box instead of going in.
Did you set the cam and crank properly when you installed the chain? Sounds like your timing is 180 degrees off.
