Need help curing mega bomb heat poblem
Old 11-08-2013, 11:30 PM
lufven's Avatar
Default Need help curing mega bomb heat poblem
I have a 2013 KX450 with A fmf mega bomb header that keeps on burning my my pants any body out there know of anyone who makes or sells a header guard or heat shield or anything that can be used to cure this problem
Old 11-09-2013, 12:41 PM
Easiest would be to get some heat wrap from a bike or street rod shop (like Summit or Jegs) and wrap it up. Another I have used is to have the pipe coated (like JetHot), which insulates the pipe, keeping in the heat for higher exhaust velocity, and cutting down radiant heat tremendously (still hot to touch, but it just doesn't radiate as much) plus something of no benefit in this case, it won't rust or corrode.
You could do the wrap and form up a guard that keeps some space between your leg and the wrapped pipe.
Old 11-09-2013, 03:33 PM
hmm, I hate exhaust wraps. For short term use they are ok. Too many burn outs of the exhaust metals. Rust, that kind of thing.
I would try the coating theory. Maybe even something like on this page....Exhaust Paint - Ceramic Coating Exhaust - Exhaust Coatings - Eastwood
Old 11-10-2013, 01:57 PM
lufven's Avatar
Thanks for the 411 I have done tried to wrap the header but tring to wrap the bomb part of the.header is next to impossible it's like tring to wrap a 6 inch long football that's 9 1/2 inches around and there is know way to keep the wrap tight it just puckers up and want stay tight and not sure if the ceramic paint is the way to go either FMF has a prototype heat sheild on the board but no release date so I guess it te to head to the fab shop thanks and keep the ideas coming all input is appreciated
Old 11-10-2013, 09:27 PM
You know, with a sand bag and a rounded body hammer you could easily make your own. It might or might not look pretty, but it will work. You could even do it with some fiberglass using the pipe as a form. Glass it up then pop it off. Then glue some of the heat wrap on the back and wrap it around where you clamp it on. That will isolate the shield. I glued some asbestos material to the back of a heat shield on my SR500. It helped.
I agree on the heat wrap. I will say the ceramic coatings work great, but again, are still hot to the touch. Somehow it stops the radiant heat.
Old 11-19-2013, 10:26 PM
Welcome
Joe Dirt
05-04-2013 02:11 AM
mikey113
06-29-2012 07:16 PM
seth6025
01-21-2011 01:39 AM
slippery750
12-20-2010 10:15 PM
slippery750
10-12-2010 05:38 PM
Quick Reply: Need help curing mega bomb heat poblem
