Hi forum hows it hangin? ^600 ninja engine probs-plz help!
Old 05-20-2009, 03:55 AM
isaacpinnacles's Avatar
Default Hi forum hows it hangin? ^600 ninja engine probs-plz help!
So the 86' 600 ninja I rebuilt works just fine except for one small detail... I've got water shoooting out both sides of the bike via a small breather hole in the head in between the cooling fins. I did everything correct. Head gasket? everything sealed, and theres only one way to put those gaskets on- the side that says this side up! Water pump seems smooth. And oil doesn't seem to have mixed. Plz advise: Any ideas would be helpf.
isaacpinnacles
Old 05-20-2009, 04:32 AM
fins on a water cooled ride? What breather hole?
Old 05-20-2009, 11:59 AM
jeffzx9's Avatar
Isaac, give us some pics. We can probably look on a diagram or find a link for you.
Old 05-20-2009, 01:37 PM
those holes you are talking about isaac are drain holes for the spark pulg well. they are for like when it rains or take a hose to it the spark plug wells don't fill with water. should be no water shooting out., of anywhere! check the top hoses and see if their tight.
Old 05-25-2009, 04:34 AM
Welcome?
Old 05-25-2009, 10:05 PM
oops, yes, welcome to KF
Old 05-30-2009, 01:29 AM
YOu weere completly right about strong arming those hoes lol thanx again! wish I could bestow upon you the true-est blessing you deserve-or even lunch on me, if your within distance... Got one more prob -idle wont hold...haven't adjusted the carbs on this rebuild. still I have to plug them with rags to get it to start pretty much. i think I barely got it started once or twice today without them while the bike was still warm. theres a slight exaust leak nothing major. i have to get a new bracket for one of the pipes. Bikes staged all the **** blowing out white smoke all over hahhahahah
thanx again you da man,
isaacpinnacles
ps. only diff is the 1/2 mm overbore +pistons and rings...Do you think valve clearenceshould be changed or double check my specs with head shop that reassembled it? Just a few more thoughts b4 I go. peace
Old 06-01-2009, 01:20 PM
Welcome to KF!
chris92
09-26-2009 04:27 AM
isaacpinnacles
09-23-2008 09:18 PM
isaacpinnacles
04-15-2008 12:38 AM
86ninja600rider
01-14-2006 11:44 PM
devestator_x
10-05-2005 04:46 AM
Quick Reply: Hi forum hows it hangin? ^600 ninja engine probs-plz help!
