I Need EXPERT advice on buying a KX125
Old 12-13-2007, 09:32 PM
rkutzner's Avatar
Default I Need EXPERT advice on buying a KX125
I have been riding a KLX250S 4 stroke for 2 years. I run a number of dual sport runs a year and love it for that. I also trail ride and would like to dapple in some motocross tracks (used to run a quad on motocross tracks). The idea of a bike that is 70 lbs lighter is VERY appealing to me (192 vs 262 dry)
I need some FRANK answers:
1.. I am concerned with lugging it too much on trails, will I be fouling plugs all the time? I'm not slow nor am I a motocross racer.
2. Are there fairly quiet mufflers for 2 strokes that are available with spark arrestors?
3. I expect higher maintenance and can do it all, but I have no experience with 2 strokes...how are they to get running right? How sensitive are they to elevation and season changes?
4. And lastly, what should I look out for when shopping for a 2000-2004 model ? Are the older ones just as good?
Any of your thoughts would be appreciated !
Rich
Old 12-15-2007, 02:28 PM
KickassKX's Avatar
Default RE: I Need EXPERT advice on buying a KX125
1) On a trail ride keep it just inside the bottom end of the powerband, this way you will be less likely to foul plugs and you wont be spinning so much, but do only ajust how many revs you use gently because unless you weigh the flywheel down its very racy; on the track keep it in the powerband, ONLY letoutof the powerbanifyou absolubtly need to.
2) Yes, the KDX125(road legal)is same engine and exhaust system.
3)2 strokes are normally sensetive to elevation changes - about 200m before you notice the difference, mine is fine with the seasons (30oC in summer and -10oC in winter)
4) Newer models benefit from years more development but the older ones are not to bad.
J
Old 12-16-2007, 03:40 AM
Knowing your ride whether it be two stroke or four stroke is a learning curve. Get to know it. Along with manual and help from the forum.
Old 12-16-2007, 08:05 PM
rkutzner's Avatar
Yes, Dragone, no doubt about it. I've rebuilt everything automotive from engines to gears and do all my own work...learning the 2 stroke should be fun and I'm looking forward to the relative simpicity.
Old 12-30-2007, 10:41 PM
jeffzx9's Avatar
You're gonna love the 2-strokers. All engines should be so "obvious."
Old 12-30-2007, 10:56 PM
rkutzner's Avatar
I'm on hold for now. The bike I went to look at wasn't as 'mint' as described. Started right up and ran great, but it's got more than the 10 rides on it that he stated. He's at 1250 now, I told him if he has trouble selling it and will go lower I will consider it. We shall see.....
Old 02-26-2008, 05:50 PM
Bobba Ganoosh's Avatar
all i can say is the 125 is a great bike and you cant go wrong with 2-stroke. I have an 03 KX125 and ive done just about everything on it and it still runs great.
Old 02-26-2008, 09:04 PM
kx slaughter king's Avatar
ORIGINAL: rkutzner
depends, you could have a 92 with a new topend and piston and it will smoke a 03' thats been beatn since it was new. be shure you ask the last time they were changed.
ds33
10-09-2012 10:21 PM
amck
KX125
01-17-2011 05:20 PM
keeen
08-20-2010 01:10 AM
Goodynole
Ninja 250R
02-28-2007 08:42 AM
Jit
06-09-2005 05:29 AM
Quick Reply: I Need EXPERT advice on buying a KX125
