03 Kx 125 clutch problem Need help
Old 02-24-2008, 08:42 PM
atrimbleracer's Avatar
Default 03 Kx 125 clutch problem Need help
I just bought a 03 kx 125 for cheap and it has a bit of a clutch problem. on the left side of the engine where the clutch is, the guy wrecked and broke a little piece off, directly behind the flywheel cover. it is right where the little clutch lever and the clutch pushrod meets. the push rod and the ball that goes inside are missing. I think the ball goes in first, then the pushrod, then the lever goes at a right angle the the pushrod. if there is anyone who knows the size of the pushrod, or the ball, knows the order it goes in, or a diagram of how it all goes in. Please help me so i can ride with a clutch again.
Old 02-26-2008, 05:43 PM
Bobba Ganoosh's Avatar
Default RE: 03 Kx 125 clutch problem Need help
I also have an 03 KX125 and when i have problems like that i go to www.bikebandit.com. If you go in the OEM section then find the clutch section it will show you a diagram of how it goes and a part list of every little part that goes there. Hope this helps.
Dscott
06-11-2013 11:13 AM
disasterouskid14
KX125
07-20-2009 03:02 AM
Spohnmeister
06-22-2009 04:20 PM
ollisdadda
KX125
03-15-2008 02:30 AM
atrimbleracer
02-25-2008 04:32 PM
Quick Reply: 03 Kx 125 clutch problem Need help
