wierd sound during load :confused:
Old 09-25-2016, 05:14 PM
taxonomy's Avatar
I don't think he can pinpoint the sound as it only happens under load. I'd just go and have a look under the clutch cover. In these kind of situations you often take things apart and put them together without finding anything but somehow it fixes the situation.
Old 09-25-2016, 05:36 PM
peabrain's Avatar
been studying the sound a bit today
*** you all know the engine has a hiss kinda sound. (air flinging around by either clutch or cam chain or valve train sound)
as the engine warms up it gets slightly louder and scraping (as described earlier) sound gets added to it and most prominent during load
when at a stand still reving the engine that sound is hard to make out but it is very faintly there
gonna buy some new oil and filter next weekend and even get a gasket for the clutch cover to take a peek at the clutch
Old 09-27-2016, 02:59 AM
GBAUTO's Avatar
I'd start with the inspection cover for the clutch-inspect the throwout bearing(clutch release) closely for signs of distress. If that doesn't produce any results you may need to take the case cover off of the r/h side of the engine and take a closer look at the clutch assm.
Old 09-27-2016, 02:41 PM
durielk's Avatar
I believe the clutch is on the left side, just say'in!
Old 09-27-2016, 02:58 PM
peabrain's Avatar
left side is stator and flywheel sir :P
Old 09-28-2016, 12:14 AM
durielk's Avatar
I had to go look, and i am WRONG!
Must of been the clutch on the other moto.
Old 09-28-2016, 02:30 PM
Have you or a prior owner forced an adjustment of the auto cam chain tensioner? I'm wondering if your cam chain is too tight as that will give a hissing or rushing sound.
Old 09-28-2016, 02:35 PM
atleastbehandy's Avatar
Check the oil filter too. I had a high pitched whine from the right side when cutting throttle. Changing the oil filter resolved the problem. I suspect the bypass valve in the oil filter acted like a whistle.
Old 09-28-2016, 03:31 PM
peabrain's Avatar
currently there is a manual cam chain tensioner in and when cold the chain is a little noisy i can try and slack off a bit more just to check
and will replace oil and filter this weekend
Old 09-28-2016, 03:55 PM
Being a little noisy when cold is normal for the manual CCT. I'd be cautious about backing it off too much, but that's certainly something to check.
Quick Reply: wierd sound during load :confused:
