What's your gearing combination and chain length?
Please post up your experience with gearing combinations and chain lengths. I'd like to compile into a table in the FAQs to add to the collective knowledge base.
For example:
Stock sprockets for the KLX250s are 14 front and 42 rear with 106 link chain. 13 & 15 fronts also work with the same chain length.
13/45 w/ 108 links is popular. The 14 & 15 work with same chain length.
What do you run or have you ran in the past?
Thanks!
What works:
Front / Rear, Links
15 / 39, 104 (snappster, post 48)
13 / 42, 106
14 / 42, 106 (stock for s model)
15 / 42, 106
15 / 42, 106 (2009 model, tight fit, atleastbehandy)
15 / 43, 106 (snappster, post 48)
12 / 45, ??? (moabmike)
13 / 45, 108
14 / 45, 108
15 / 45, 108
13 / 47, 108 (rgmr)
13 / 47, 110 (Lutz)
14 / 47, 110 (Lutz)
15 / 47, 110 (Lutz; AdventuresinRealLife, snail adjuster at 5)
14 / 48, 110 (reinigef, middle of adjustment)
13 / 49, 110 (IDRIDR)
14 / 49, 110 (IDRIDR)
15 / 49, 110 (IDRIDR)
13 / 50, 110
14 / 50, 110 (TNC's favorite, 2006 snail adjuster at 1.5)
13 / 51, 110 (2006 snail adjuster at 1.5 with a new chain, IDRIDR)
14 / 51, 110 (adjuster at -0.5, IDRIDR)
15 / 51, 112 (IDRIDR)
What doesn't work:
Front / Rear, Links (Notes)
13 / 49, 108 (seemed too tight with axle adjusters forward, insufficient slack)
15 / 51, 110 (IDRIDR - needs a 112 link, see 14 / 51, 110 notes above)
For example:
Thanks!
What works:
Front / Rear, Links
13 / 42, 106
15 / 42, 106
13 / 45, 108
14 / 45, 108
15 / 45, 108
13 / 47, 108 (rgmr)
13 / 47, 110 (Lutz)
14 / 47, 110 (Lutz)
13 / 50, 110
What doesn't work:
Running a 13/47 on mine with a 108 link chain. My son's KLX250s is running a 13/49 (he's a big guy, so the even shorter gearing helps) with a 110 link chain. The 108 link with the 13/49 seemed too tight even with the axle adjusters all the way forward, so we went to a 110, to keep proper slack on the chain.
I'm running a Moose Racing rear chain guide (stronger than the stock one), and with the 47T sprocket, I had to cut a little out of the upper wear block on the chain guide or the sprocket teeth would gnash on the wear block.
We do 90% tight woods single-track riding, so the 13/47 and 13/49 combinations are great for it - I wouldn't want to ride with any taller gearing now that I've had a chance to try this gearing. If I was commuting, I'd probably leave the stock 14/42, though.
If you're doing tight single-track with lots of steep hills like I'm doing, the 13/42 just doesn't cut it.
rgmr:
Thanks, exactly what I'm looking for!
I too ran 13/49, and also 14 & 15 with the 49.
I'm currently running 13/51 (and need to re-count links). You don't want to ride 13/42 to Wildhorse Lookout. But, please, let's keep this thread to what works (and what doesn't work). Let's not turn it into a "what gearing is best" thread, nor into a "what oil is best" thread .
Scott, 14/50 is "the best" setup for off road. Oh...sorry...I just now read your warning about not making this thread a "what gear numbers are best" thread...LOL!
But seriously, that's what I run on my '06 with a 110/100 18" rear tire. My chain is a 110-link, and the adjusters have the axle pretty close to max forward position at the 1.5 number on the snail adjuster number range. For off road I prefer the rear wheel as close to the front as is reasonably possible on this bike for my riding. While agreeing with you on not making this thread a "what's best" issue, I would say that the 14T front sprocket is probably the best selection sprocket as the 13T really tightens the chain arc for the 520 chain. I think it's best to do a larger rear sprocket to lessen this issue. And if someone actually even makes a 12T for this bike, I think that's a formula for serious chain abuse. A 520 chain will not like that at all.
Here's a link to a nice, concise Thumpertalk thread on a 10-point issue about dirt/DS gearing. Hardly the "do-all", "end-all" for the issue, but it's a nice reference point.
10 Secrets Of Motorcycle Gearing - General Dirt Bike Discussion - ThumperTalk
Thanks, Thad.
So, can I assume that although not ideal for chain karma, a 13/50 would also work with the 110-link but a 15/50 is questionable and may need 112-link?
Good article.
Good article.
Is the effective chain adjustment distance the same on both models of the KLX (I mean '06-'07 and '09-'15, not the S and SF)?
I know any gearing/chain combo has worked for me on a '12, just as it has for you guys with the older model. That's where I got the gearing info.
More curious than thinking it's a problem...
I think a 108 gives the most options if you want to go from street(stock equivalent) to a good trail set up. I've run a 14/47 108 but it was tight to the front of the swinger, almost too tight with a 120/80 D606.
