What is this part and why is it capped ?
Old 05-01-2016, 12:47 AM
TheDoc46's Avatar
Default What is this part and why is it capped ?
What is the use for the bottle that's hanging off the pipe, which if my memory serves me well, leads back to the tank, making it some sort of breather or gas overflow collector?. The one that has a cap on it. Which kinda defeats it being an overflow, if that's what it is... Clearly i have no idea what it is, so i come to you internet friends !!!!
Anyway i've lost the cap, and wondering what it is, and if i should bother replacing the cap?
Old 05-01-2016, 12:57 AM
Ruggybuggy's Avatar
I think that's the drain for the air box but I'm guessing. I have to work on the bike tonight so I'll check.
Old 05-01-2016, 01:10 AM
That little translucent bottle and capped line is the drain from the air box. It is a pollution control, keeps any oil from dripping out on the ground. They figure you will uncap and drain the mung out and properly dispose of it.
Most people uncap it or take it off at the bottle.
Old 05-01-2016, 02:41 AM
durielk's Avatar
I found one of those too, but it was all bashed so I threw it away.
Old 05-01-2016, 10:05 PM
TheDoc46's Avatar
Yes its definitely a drain / breather from the air box... Had a look on kawasakiparthouse.com
Does that much oil ever come out of the airbox ? What incase people spray up their filters too much or something ?
Old 05-02-2016, 02:07 AM
durielk's Avatar
If you oil your filters with regular oil, it run's out.
Old 05-02-2016, 01:16 PM
Klxster's Avatar
Your bike is male.
Do us a favor, tuck that thing up where it doesn't show all the time..geesh..
Old 05-02-2016, 10:17 PM
Could be a problem with it open and with it closed.
Closed, if water gets in the air box there is no escape. It will lay in there until drained... or sucked in the carb. Not really too likely an issue unless you get in serious WAAAY deep water that goes in the snorkel or in over the edge if no lid. Or if you spray water up under the seat area and enough gets in there.
Open, if you get in deep enough water it will come up through the breather into the air box. Only could happen if you spend enough time in water above the carb line of the air box where it can actually fill up.
Is either scenario likely to happen? Probably not. But there is the possibility if you get in the extremes. I don't, so I don't worry. I have it open. I don't plan on submarining the KLX.
Old 05-03-2016, 01:45 AM
Most people just remove it, many times after it has been smashed on a log etc. The whole thing is there to save the environment,,,, Catches the oil so it does not just drop onto the ground..... Probably dictated by EPA or Kawi lawyers. Mines been gone for years.
Dan
rambleongirl
08-10-2009 03:02 PM
je2000
05-03-2009 05:01 PM
kwenui
02-20-2009 02:32 AM
NicePaint
Joke section!
13
11-26-2007 03:50 PM
speedracer138
09-09-2006 07:52 AM
Quick Reply: What is this part and why is it capped ?
