?valve clearance adjustment?
Old 03-19-2014, 05:24 PM
justtrust's Avatar
Default ?valve clearance adjustment?
shim was 3.10 giveing clearance of .127 S0 3.10 + .127 - .19 = 3.037
I put a 3.00 in and am geting clearance of .203 Out of the .19 spec
Bike is back together and now I am paranoid about the Gap.Will this be ok?
Old 03-19-2014, 08:26 PM
Brewster's Avatar
I would go with the 3.05 to set the clearance in the middle of spec.
Ride on
Brewster
Old 03-20-2014, 04:16 PM
justtrust's Avatar
Thanks I know thats the right thing to do. I just was curious what sum of
the adverse affects or positive affect might be to my out of spec gap.
Old 03-20-2014, 05:04 PM
ol'klx-er's Avatar
That one valve just won't be opening quite as wide as it should which is better than having a valve which stays open longer than is should (less clearance than spec). Valve clearance less than spec doesn't let the valve transfer it's heat to the valve seat = burned valve.
Old 03-21-2014, 06:25 AM
justtrust's Avatar
Thanks ol'klx-er that is just what I needed.
Old 03-23-2014, 07:47 PM
CaptCapsize's Avatar
Also be sure to measure the both the new and old shim. I found they are not always exactly the marked dimension.
Old 03-23-2014, 11:27 PM
justtrust's Avatar
I will measure both and post if thay are a different dimensions.
Also do you try to clean the old glue off the gasket or just apply more over the old.
If you clean it how do you recommend I do that?
Old 03-25-2014, 10:20 PM
preload's Avatar
Default What milage on the bike for this Valve check?
Hi,
Is this the first Valve check? If so, what mileage is on the bike?
Thanks.
Old 03-26-2014, 12:33 AM
justtrust's Avatar
Yes this was the first valve check
3800 miles.
I did not think it needed it but I was installing a BB351
It was just out on the left intake
Both exits were still in the upper limits
Old 03-26-2014, 03:34 PM
Arickrock's Avatar
Anyone got a specific model # on a valve shim kit they would recommend for this job? I am quickly approaching 7,500 miles and need to prepare for this project. Thanks.
Quick Reply: ?valve clearance adjustment?
