Trail Riding Essentials
It's also worth replacing the tools in the standard kit with items that are made of actual steel instead of case-hardened cottage cheese. Decent spanners take up no more room than the standard gear and will serve you far better.
Ok cool. Duct tape and electrical tape are good ideas. I'll have to go through my tool kit to see what's there and add any necessary items.
From reading ride reports I am under the impression that the rear tire is the one that fails 9 times out of 10. Is this correct? Would it be worth carrying a spare tube for the front as well as the back?
Thanks for the ideas. Keep them coming.
What all you carry depends on what type of riding you do. Gravel roads thirty miles from civilization, maybe you carry more. Trails three miles from the truck, maybe you carry less. Some guys on here carry everything but the kitchen sink. For the riding I do, and so I don't weigh myself down too much, I keep mine pretty basic. I still feel I can , at least make it back from 20 miles out, maybe not with a full repair, but at least not be stranded.
Knobbie tires have a pretty sturdy sidewall, so you can ride on a flat if you have to . Zip ties around a flat or a rim lock will keep the tire from shifting around the wheel too much. I carry a front tube, it can be used on either wheel in an emergency. If you have a rear flat you can just stuff it in there, it will be twisted but it will air up and get you by.
Tire irons, a couple allen wrenches, needle nose vise grips, a cut down crescent wrench, spark plug socket, zip ties , tape, Small stick of instant epoxy, spare master link, razor blade, butane lighter. There may be a couple more items but it all fits in my camelbak (tube and irons are in a fender pack ).
One of my riding buddies carries a can of fix-a-flat. The last ride, he got a flat about 2 miles from no where. The fix-a-flat worked very well. It got us back to basecamp so he could do a tube replacement. I don't think you would want to continue on a ride without a real fix. Also, this approach would only be good if you had rimlocks, since it wouldn't help if you lost a valve stem.
I always bring my GPS on trail rides, so if I need to bail out, I can find a way back home. I use a hiking GPS (Garmin Oregon).
I forgot to mention the small allen wrench needed to open the float bowl. You'll need one with the ball end so you can use it at an angle, thanks to the header. It's been very handy.
I have a piece of a wire coat hanger folded up
I forgot to mention a tow strap. If you're riding with someone else, sometimes it's better to tow your bike to a place where you can pick it up with a truck/trailer and take it somewhere more convenient to fix it.
