Throttle cable routing
Old 02-25-2017, 03:39 PM
bryan632's Avatar
Default Throttle cable routing
I just installed new bars on the bike. Got the pro taper se bars. I believe they are the cr mid bend. The throttle cables are a bit short. The bike revs when the bars go full left. I checked the FAQs, but the links don't seem to be working. Does anyone know a good place to reroute to get the tiny bit I need?
Old 02-25-2017, 09:36 PM
Brewster's Avatar
If you can't get the needed cable clearance, Motion Pro can set you up with custom length cables.
https://www.motionpro.com/motorcycle/custom/
Ride on
Brewster
Old 02-26-2017, 03:23 PM
I am only running the open cable (aka pull cable) due to the close cable being kinked and not having a replacement at hand. I will say when I had the tank off the first time I saw the cable running down under the tank - and tight. I ended up with the cable running along the inside of the right frame spar between it and the gas tank. Made a better run with less tightness in the curves. Take a look, it may work for you.
In addition after a ride you may or may not find you need to shorten the bars. I have 3/4" per side cut off the Renthals on my bike, I needed a bit narrower. Don't know the bend.
Old 02-26-2017, 03:28 PM
bryan632's Avatar
Thanks. That's the exact info I was looking for. I'll check it out.
queen of spades
05-24-2016 05:54 PM
CousinLarry
05-11-2010 12:24 AM
joeyv69ragtop
Ninja 500R
07-03-2008 12:44 PM
KLXer
03-13-2007 02:54 AM
rkutzner
11-26-2006 02:10 PM
Quick Reply: Throttle cable routing
