size hone for KLX300R cylinder?
Old 10-31-2016, 01:23 AM
queen of spades's Avatar
Default size hone for KLX300R cylinder?
Gonna run with a 300 cylinder I got on ebay. I'd like to very lightly scuff the plating and am unsure what size hone ***** to order. The cylinder is just over 3" in diameter. What size hone ball do I need?
Old 10-31-2016, 02:04 AM
Klxster's Avatar
Deglasing a nickasil'd bore is optional ..? Scotchbrite red goin round n round, never up and down, will do it.. Not sure the ball hones are capable of deglasing nickasil..
Old 10-31-2016, 07:37 PM
s10gto's Avatar
I agree. I have used a sunnen power hone to remove melted piston from snowmobile cylinders. Unless you use a diamond hone a std stone will not touch nickasil.
Scotchbrite it and call it a day.
Old 11-01-2016, 02:55 AM
GBAUTO's Avatar
Ditto-all you can do is try and remove any deposits-the surface coating is not going to be touched by anything less than diamond hardness. If the bore has scratches that go below the surface then the only way to fix that is a replate.
Old 11-01-2016, 05:08 PM
Scotch bright it is. Wiseco piston kit should be here this week.
KLX300S, here I come!
http://dpippin.com/klx/index_files/Page1666.htm
Old 11-03-2016, 04:58 PM
s10gto's Avatar
250 to 300 Upgrade
Interested in how you like the 300 when done. Please keep us updated.
Old 11-05-2016, 11:02 PM
Hoot's Avatar
Me too.
You planning on getting a pumper carb or rejetting the cvk?
Old 11-05-2016, 11:24 PM
I installed a DJ kit a few months ago. Won't change jetting unless needed.
Old 11-06-2016, 01:34 AM
Hoot's Avatar
Ok. What about the MCM and KACR? Have you done those yet?
Old 11-06-2016, 01:42 AM
Going to pass on the MCM, just learning about the KACR a few seconds ago: https://www.kawasakiforums.com/forum...-klx250s-7167/
Quick Reply: size hone for KLX300R cylinder?
