setting rear sag
setting rear sag
I tried searching, but apparently the search engine doesn't work with three letter words. Is the rear suspension travel 9.1"? What are you setting your sag at...25%-30%? Is there an easy way to adjust the preload...can someone recommend a spanner wrench or should I just use a hammer and punch to turn the nuts? BTW, I have 3.75" of sag now so that's about 41% of total travel if the travel is actually 9.1". I weigh around 180 with gear.
Did you try searching through the FAQs? I bet most of the answers are there.
https://www.kawasakiforums.com/forum...q-links-30733/
You might want to let us know which bike you have.
The guideline is 1/3 of travel, WITH THE CORRECT SPRING WEIGHT!
Put the bike on a stand when making the adjustments to make it easier to spin the nuts.
Ride on
Brewster
Ride on
Brewster
Oops, it's an '09. Is the spring marked for what rate it is?
According to RaceTech calculator RT - Digital Product Search your good to go with the rear stock rate.
