Replacement Throttle Tube for 2006??
Hello,
I am trying to find a replacement tube for a 2006 and am not having much luck. The last tube I bought was a Zeta High Speed Throttle Tube
SKU: ZE45-5101, which had a larger inner-ring than the 2006 takes (sold to a member who put it on his 2009, I believe). Has anyone had any luck with an aftermarket quick-turn tube for a 2006?? I saw this one, but I am not sure if it will fit, and I don't want to spend the money on it unless I know for sure:
http://www.ebay.com/itm/Klx250-Klx-2...d9c5ed&vxp=mtr
Thanks in advance,
Luke
Thanks in advance,
Luke
Luke,
Sorry, I can't answer your question. But I do recall a conversation here or on another forum warning against aluminum tubes for dirt bike riders. Something about the risk of having a throttle stick from a crash and dent, and that the plastic ones may rub but wouldn't stick as easy. No personal experience. YMMV.
I suppose I'll have to order the stock plastic replacement... unless there is a good way to upgrade the throttle housing to 200x date that is compatible with the quick turn throttles some of the members here have?
