Picking up a set of used rims. What do I need to know?
I'm trying to understand rim sizes and what will work on the klx. I want to buy a set of used rims locally and put together a street set of wheels. Most ads just say "18 and 21 inch used spoked rims for sale". There's gotta be more to it than that, right? Or is it really that simple?
EDIT
1.60 x 21
2.15 x 18
Got it...
The wheel hub will be the biggest problem I see. Need to find out what alternatives are out there
EDIT
1.60 x 21
2.15 x 18
Got it...
Been looking into it more. Would a KDX220 set of rims and wheel hub fit? They don't share the same part numbers, but are damn close. And cheap to come by used.
Wishful thinking...
Wishful thinking...
Your wish has been granted. maybe.... Some KDX wheels fit some KLX's. Looks like you are are in Taiwan. I have a 2007 and this is a thread i started while researching compatible wheels. Don't have time to write more now, but should get you started.
Good luck ,,, ,Dan
Good luck ,,, ,Dan
Thank you. That's reassuring Dan888. I found your thread
https://www.kawasakiforums.com/forum...-wheels-36873/
I would assume the wheel assembly of a 2007 klx is the same as a 2014? Second half of many of their part #'s are different. But so are the KDX's...and that fit yours. So I may take a shot at a set. Can't find them here, but overseas shipping isn't too bad if I can pick them up cheap enough.
Will be nice to save my new knobbies some wear and tear.
No, I don't think so. The front hub has to be for an electronic speedo and I believe they are different. I think the rear hubs are the same. You need a 2009-2014 front hub.
If anyone knows different, please step up and correct me. I'd love to be wrong. Then I could get a set of KLX300/KDX200 wheels to put knobbies on them.
Dan
