Off topic - DRZ-110 isssue
Old 06-30-2007, 06:04 PM
pooliod's Avatar
Default Off topic - DRZ-110 isssue
I know this isn't the '250, or Kawa for that matter, but you guys have been very knowledgeable in general, so here goes...
My son's '04 DRZ-110 has a problem returning to idle after a rev. It is kind of dangerous because it wants to keep going when in gear. You really have to apply the brakes to get it to slow, no engine decel at all. Any ideas? I tore the carb apart and found the pilot jet clogged, which fixed the "only run w/ choke" issue it also had. It otherwise runs strong.
Thanks,
Donnie
Old 06-30-2007, 07:44 PM
Default RE: Off topic - DRZ-110 isssue
It sounds like a cable is sticking. But a good test is with the bike off, twist the throttle all the way and then let it go, does it snap back? Just a thought.
Old 06-30-2007, 08:03 PM
vtgreen's Avatar
What deej said, or hanging/holding revs is often an indication of a vacuum leak somewhere. Does it eventually come back down to idle?
That's what this guy found.
https://www.kawasakiforums.com/m_148825/tm.htm
Old 06-30-2007, 09:42 PM
MaverickAus's Avatar
Sounds like a vacumn issue, check the vacumn hoses for kinks, blockages, etc. Have you had the tank off? Maybe kinked a line?
Old 07-01-2007, 02:13 AM
Will Shoe's Avatar
Clean the entire carb if you havent, make sure the spring on the carb will snap close when you let off, do what deej said also. Follow the throttle cable and make sure there are no cuts or anything in the line where the line could grab something.
Will
Old 07-01-2007, 06:18 PM
pooliod's Avatar
Thanks everyone. I will investigate the vacuum and Deej's suggestion. It does eventually come back down to idle.
Donnie
IchWarriorMkII
05-21-2006 06:36 PM
deej
04-17-2006 04:39 AM
jayden
02-27-2006 07:14 AM
deej
02-01-2006 05:58 PM
Shane250
10-26-2005 11:41 PM
Quick Reply: Off topic - DRZ-110 isssue
