Noise on suspension compression
Hello,
I have a 2012 klx250s, but thought I'd ask about something I haven't been able to figure out yet. I've noticed what sounds like something rubbing when the suspension partially compresses, but I know not what. It's not a full bottoming out problem, I've noticed it on curvy mountain pavement where the road contours for drainage. Also when I gave someone a ride around the residential block while crossing the intersections. I looked for rub marks from the rear tire, nothing. I thought it might be the upper chain roller. Is this normal? I weigh about 200 lbs, I tightened the spring preload about 1/2"
John U.
John U.
OK, thanks. Where is a good place to get a stiffer spring? A modified skateboard wheel would be quieter if the stock one just has a sleeve bushing/bearing. I was at one point thinking of just stuffing a coil spacer on the shock spring, probably a bad idea, but what about when you have a passenger, it's another 100+ lbs instantly.
I never heard of this "upper chain roller", maybe that is where my squeek is coming from when the rear suspension moves up and down.
I tore the whole rear end off and lubed everything, and the squeak was still there.
d
d
Look and see. There should be a little roller on the left side where the upper chain rolls when closing in on fully compressed.
Any harm in removing the upper wheel? I think this has been covered on the forum. Someone actually had one tear off of the frame. May have been the KDX forum? Very similar setup.
Thanks IDRIDR. I'm in Cali so Race Tech would be local. I googled Cogent and got Cogent Dynamics for suspension.
When I was shopping for my bike I remember reading that the roller was one of the 'flaws' of the DR650, and it was a good idea to remove it before it came off, along with a section of the frame. Although, too much chain 'whip' = broken parts along the chain path.
You sure it's not just the plastic mud flap thing that hangs down between the front of the swing arm and the tire tread to protect the shock? That plastic flap makes noise on most bikes as the suspension moves.
