New Rider
No I have not touched the chain yet, but will look into how to adjust it as I have never done that before.
Its definitely not chain lube, I found the crack in the case that was leaking the oil.
Sounds like you found your oil leaking problem, but I would add one suggestion to those mentioning cleaning the countershaft area of gunk. I would recommend not using any solvents or spray cleaners in the countershaft pocket...unless you're super careful about not getting those chemicals on the countershaft seal.
For one, that pocket doesn't have to be very clean. Just using a screwdriver or device to scape out the big chunks is all that's needed...again, being careful when using sharp devices around the countershaft seal. Yes, the countershaft seal is a tough ****, but some chemicals will harden the flexible characteristics of the rubber seal shortening its life. Unless you know beyond all doubt that the chemical you're using is absolutely safe on rubber, it's just not necessary to hose down the area with chemicals to dissolve the gunk. Warm soapy water not sprayed directly in there like a firehose is plenty good and just scrape the bigger stuff out by hand/tool.
In my experience, when you use glue on metal, that joint has to be clean. Really clean, so you need to decide what it the best way to do that. 1. Soap, muscle, & water or a very 2. good cleaner (solvent). I would do both, 1 then 2 using the solvent very controlled method.
