Need help!!! webcams 101 or pumper carb
Old 08-22-2014, 03:31 PM
mikezx10's Avatar
Default Need help!!! webcams 101 or pumper carb
Ok all, I have Mr. Blue's kit sitting on my workbench ready for install. I have my cams packaged for shipping. Im sitting here about to order dynojet kit and it occured to me that instead of the cams...maybe I should get the pumper??
Old 08-22-2014, 03:56 PM
TNC is offline
You'll probably get different views on this. The 34 or 36 pumper is a great improvement. However, in your case you're doing the 351 and one other mod. You're already invested a great deal in this project. Can you imagine what the 351, cams, and 36mm pumper carb would add to the overall performance if all done together? Personally I think Bill's carb setup is a little high when compare to getting the TM36-68. It works excellently on my 300-jugged KLX, and I'd never consider going back to the CV carb unless I was preparing to sell my bike. BTW, either pumper carb equals or exceeds the mileage of a modded CV carb
Old 08-22-2014, 04:12 PM
mikezx10's Avatar
thanks for the quick reply... still sitting here scratching my head! I am eventually going for all mods but not sure which one is better first. In my head im thinking:
1) BB351
2) webcams 101
3) tm-36-68
4) programable CDI (just because I want to see if it has any benifit with all the mods)
Just wondering if spending the $50 on the DJ kit is a throw away??
Old 08-22-2014, 04:43 PM
TNC is offline
Well, since you'll have the motor apart to a large degree for the 351, you might as well do the cams at the same time. The carb can easily be added later without much mechanical drama.
Old 08-22-2014, 06:16 PM
RockabillSlapMatt's Avatar
Larger intake valves and a polished head will gve more benefit with a pumper than just cams with the stock carb. Tm36 for a pumper too btw
Old 08-22-2014, 06:35 PM
mikezx10's Avatar
I have 2 motors the one in the bike is still complete.
I am trying to get all the parts together before I open up the bikes motor!
thanks guys I will do cams with 351 and pumper after! Any sugestions on where to purchase carb??
Old 08-22-2014, 06:58 PM
Mikuni TM36 Flat Slide 36mm Pumper Carburetor - Accelerator Pump
use the $15 in store cash once you buy the carb and in a second transaction buy jets and needles for your elevation.
Old 08-22-2014, 07:07 PM
mikezx10's Avatar
Why thank you sir!
Old 08-22-2014, 07:46 PM
Broussard's Avatar
Default Cams
Just finished up replacing the head on my 351, and while I was at it put Webcams 101 and deshrouded the valves. The shrouding in this engine's head is pretty terrible.
I cc'd the combustion chamber repeatedly through the process to make sure I did not bring the compression ratio down below 11:1
Still on the stock carb.
EVERYTHING about the bike is better - starts easier, idles smoother, better mid-range, better top end. I expected the cam to really help the top end and not much else, but the bike is noticeably better all over.
67 mpg on last run through the mountains (street, I've got an SF).
Old 08-23-2014, 12:57 AM
mikezx10's Avatar
thanks for the quick review on the cams! i too have the SF... u know it is a blast off road right!?!?
Oh and what do you mean by deshrouding? I never heard that term.
Quick Reply: Need help!!! webcams 101 or pumper carb
