Service Manual request
Well I have decided to go big bore & I am going to do it without the manual. Benn there done that & I am comfortable doing this except for machine specific issues. I found the torque specs on this forum from a member (thanks). The only area that even has me slightly wondering is the cam chain tensioner. Could someone post this section (Bryanttj?) Thanks!
PS, I have some farkles on the way thatI hope willbe the dogs dangles!
RE: Service Manual request
Cover Bolts 7.8 N-M
Camshaft Chain Tensioner Mounting Bolts 9.8 N-M
Chain Tension Spring Bolt 15 N-M
Camshaft Cap Bolt 12 N-M
Camshaft Sprocket Bolts 12 N-M
Camshaft Cap Bolts 12 N-M
1st go Cylinder Head Bolts 8mm15 N-M
2nd go Cylinder Head Bolts 8mm46 N-M
Cylinder Head Bolts 6mm12 N-M
Valve Clearances (cold)
Inlet 0.10 ~ 0.19mm
Exhaust 0.15 ~ 0.24mm
Hope this helps
Cheers
Inlet 0.10 ~ 0.19mm
Hope this helps
Cheers
Mr. Bo Jangles
11-09-2008 06:17 AM
j_christopherhall
11-10-2006 08:01 AM
