More carb problems
More carb problems
Soo, after taking my bike to the mechanic to check that the idle is all good, I was driving home and lost the whole idle screw spring and everything... So I bought a new assembly and put it in and while I was at it i tore apart my carb to clean it but it looked brand new. I still sprayed carb cleaner through all the jets and pilot, anyways. I'm trying to get my bike to idle and what should be a 10 mins thing has taken me 5 hours and its still not done, I have the screw out like 4 turns atm and its idling at like 3000rpm when its 3 turns out it idles at 1000 then bogs down and dies and anything under 3 turns seems to do the same thing. Soo do I need a new pilot jet? I'm kind of confused because it had been idling just fine for quite a while. Like 8 months before this problem came about.
also just looking at kawasaki parts it looks like there is only the 35 for pilot?
Lets assume: The the bike used to idle just fine at 1200-1300 rpm with the fuel screw @ 2.5 to 3 turns out. You have the correct replacement fuel screw and spring. After your carb "teardown session" , it won't idle at 1200-1300 rpm with the fuel screw 2.5 to 3 turns out.
If all the above is true - then your carb teardown session created the problem. I guess, read this thread and see if it helps? - https://www.kawasakiforums.com/forum...s-fixes-43146/
I didnt actually open the diaphragm area, I decided everything looks so clean I wont bother, update, yes the bike was running fine before hand, but I had to have the screw ore than 3 turns out more like 4. so the screw fell out I got a new one tore down the carb and then put the new on in, I still couldn't get it to idle without 4 turns out so right now I have my bike idling great. and I have the hole plugged with a was of Teflon tape to stop the screw from coming out.
theswits
09-13-2007 04:11 AM
