Longer Throttle Cable for 06 -07 bikes
Old 03-04-2011, 11:39 PM
wildcard's Avatar
Originally Posted by GaryC
4 inches longer????
that's quite a bit huh??
Thats what she said !!!
ZING !
Old 03-04-2011, 11:40 PM
FlyingFinn's Avatar
Some to allow proper routing to TM36 around the IMS tank, and some more to leave slack for higher bars.
TM36 alone can be installed with stock cable. But I want to route the cable "the long way around" the head stock. That gives a smoother route to the TM36 and helps with the congestion under the IMS tank.
I also get my condoms custom made 4" longer than normal so I'm used to this. I understand if you guys aren't...
Mikko
Old 10-15-2011, 09:09 PM
GaryC's Avatar
What is everyone doing about the clutch cable?
I am installing bar risers and need longer EVERYTHING cables.
Just curious but does anyone know if the KLR650 cables are longer than stock KLX250 cables?
Old 03-21-2014, 02:28 PM
Thread bump....
The pre- '08 KLR650 clutch cable is about 2 inches longer, and '08+ KLR650 about 4-inches longer than the '06/07 KLX250 clutch cable. Fittings aren't quite the same, but it looks like the KLR cables will work on the KLX250 in a pinch.
Old 03-21-2014, 03:08 PM
TNC is offline
Originally Posted by IDRIDR
Thread bump....
The pre- '08 KLR650 clutch cable is about 2-inches longer, and '08+ KLR650 about 4-inches longer than the '06/07 KLX250 clutch cable. Fittings aren't quite the same, but it looks like the KLR cables will work on the KLX250 in a pinch.
Scott, what was the outcome for your 36 pumper throttle cable mystery?
Old 03-21-2014, 04:21 PM
Once everything put together, the stock throttle cable fit after all. I still would like the wire cable to be about 1 cm shorter (or even better, the sheath to be 1 cm longer) as the carb-side adjuster is nearly fully out, the button is in the far position on the carb, and the throttle side adjuster is out a but further than I'd like. However, there's been some other issues and I haven't got to ride yet so we'll see what happens.
Old 11-22-2014, 03:25 PM
Update: Motion Pro should now have dimensions of the 2006 stock throttle pull cable on record. Note this is pull cable only.
Rosed
09-21-2013 04:07 PM
djchan
12-20-2012 06:03 PM
GaryC
02-20-2012 12:29 PM
punkenduro09
04-11-2011 04:29 AM
cmon6969
04-16-2009 11:16 PM
Quick Reply: Longer Throttle Cable for 06 -07 bikes
