KLX250 stalling
sounds a bit like water in the fuel. coming from a place with 400 inches of rain a year I deal with something that sounds similar... cross a river, suck in a splash, bike will run but when you try to put load on it sputters and stops....
There may be other ways, but none I'm aware of.
Check the water in both rads the second rad has a bleed cap take if off when you fill it up my friend had the same problem he stripped the carb changed the CDI replaced the coil and lead plus plug AND THEN found there was no water in the second rad so the sensor was cutting the bike out - It may work it did for my friend
