Bags and subframe
Old 03-21-2012, 02:02 PM
stephenmarklay's Avatar
Default Bags and subframe
One of the first things I will be doing to my new bike is saddle bags. These will be used for everyday commuting, clothes, groceries and the like.
I have read about the sub frames issues so I want to avoid that to the extent possible.
Will a set of Dirt Bagz that go over the rearward seat area be less stressful to the week rear sub frame?
I thought about a pannier specific rack like happy trails sl but the mounts make me think this may make the problem worse. I can really load up the groceries.
I would do a cyclerack if that is the best solution even thought I don't love the added pannier attachment vs a single welded unit like the Happy trails SL.
Thoughts?
Old 03-21-2012, 03:02 PM
Less stress than this? probably. LOL
Old 03-21-2012, 03:45 PM
rgoers's Avatar
I lift my '09 by the subframe all the time. That has to be lifting about 1/2 the weight of the bike, at least. I'm wondering if the "weak subframe" was; A) Fixed by '09, or B) The result of someone RIDING on the rear fender. I can't imagine it not holding 100+ pounds. Seems plenty sturdy to me for most legitimate uses.
Old 03-21-2012, 03:49 PM
There are only a few reports of subframe problems that I recall, usually from a floppy load on lots of fast hard bumps and stuff. I've loaded the heck out of mine, not quite like Deej, and its done fine. The cycle rack does a good job of transferring load down lower, which seems to make a lot of sense.
Old 03-21-2012, 06:18 PM
I guess the search function has me skewed a bit
Old 03-21-2012, 06:52 PM
At least one member here as suggested the 2009+ subframe may be a little weaker in spots than the 2006/2007. Skim through my Owyhee and River of no Return ride reports below to see some pics of my loaded 2006 and the terrain.
Old 03-22-2012, 03:16 PM
rgoers's Avatar
I have the Wolfman E-10 Enduro Bags on mine. They hold quite a bit of stuff, without being overly bulky. There's a duffle that you can strap to the top for additional storage.
Wolfman Motorcycle Luggage
They are expensive (IMO) but the build quality is top notch. I suppose you could throw a lock on the zippers if you felt you needed to. The way they attach makes them NOT very friendly to frequently removing them when you stop.
Old 03-22-2012, 06:12 PM
RaceGass's Avatar
Frame thickness is about the same from 09 to earlier years.
Check out
http://klxforum.suncup.net/viewtopic...636e8772696021
I wouldn't be jumping or slamming any whoops loaded down on any year klx without doing some extra gusseting
Old 03-22-2012, 07:28 PM
Thanks everyone. I am 99% certain I am going to get a Cycleracks rack. It distributes the load and will give me peace of mind in exchange for a bit of ugly...
I might weld on some side rails like the happy trails sl rack for panniers.
Old 03-23-2012, 01:42 PM
MaverickAus's Avatar
It's not difficult to make the subframe stronger, then you have piece of mind
Quick Reply: Bags and subframe
