KLX 250S speed sender removal ???
Old 11-18-2016, 07:40 PM
moabmike's Avatar
Default KLX 250S speed sender removal ???
How does one get the speed sensor out of the front hub????
Old 11-19-2016, 12:43 AM
doum's Avatar
I think zeta have one gear canceller for that purpose.
Old 11-20-2016, 02:04 PM
Josh128's Avatar
When you remove the front wheel it comes right off. The wire is hard-wired into it and you will have to remove the wire all along with it. When I changed my front tire the other day I saw all this.
Its just a magnetic sensor that senses little metal ears/flags that pass at every half turn of the front wheel.
What exactly do you need to remove it for, did it go bad?
gthomas17
09-30-2015 06:53 AM
Gteeiguy
10-14-2013 03:23 AM
Xpress
11-20-2010 04:46 PM
jpaul310
08-10-2008 10:41 AM
gerrynolan
07-12-2007 02:53 AM
Quick Reply: KLX 250S speed sender removal ???
