Klx 250s mods and supermoto kits?
Warp 9 Supermoto Wheels - Motostrano.com
Klx300f application should fit just won't have a speedo gear
Price wise ? about $850 for used wheels (ebay) a 12o'clock labs speedo adjuster (needed cause you speedo will read REALLY high otherwise) and a new front sprocket to bring the gearing back to something usable as the S has much lower gearing due to the larger wheels.
If you get wheels with the SF front rotor you will also need a caliper relocation bracket as the SF rotor is much larger on the front.
general conversion info -
http://klxworld.blogspot.com/2014/04...g-s-to-sf.html
caliper bracket info -
http://klxworld.blogspot.com/2014/03...ake-to-sf.html
