how to clamp cr style brake line.
I have an aftermarket stanless steel braided line that the PO installed. So I don't have the old stock one. I think Lowes has poly air tubing I can try if I can find the correct ID size.
I'd say try some thick wall shrink tubing. Take a look here at www.heatshrink.com and get a size like 3/4" ID that will shrink at 1:3, it will shrink from 0.75" to 0.25" ID.
Click on the data PDF link to see the full specifications. If it can slide over the fitting then shrink it down with a heat gun. It isn't cheap at around $10-11/foot with 4 foot length. Possibly an electric shop or doing a bit more searching can get it local and/or lower cost. Maybe 1/2 or 3/4 ID can slide over the fitting.
Both good ideas guys. I do have a big truck stop about 30 minutes away that has everything. That heatshrink would be perfect to hold the slit opened air line, giving it a factory finish. Nice and clean, done the right way. Perfect....Thanks guys.
