Headlight Is Dead.
Headlight Is Dead.
Every other component on the bike is in working order.
Assuming that the bulb isn't burned, please, someone, list every possible theory as to why it could not be receiving power.
Thank You.
Thank You.
OK helps to say that straight up.
As durielk said next place to check is fuse if not that then start looking for connectors that have come adrift or bad earths.
Just a thought if you have a multimeter it doesn't to check the continuity of the bulb, it is possible to have a bad filament and not be able to see it.
From memory it's under the seat but I could be wrong. And yes I'm sure it has it's own.
Got this off another forum
Remove the seat, slide the rubber cover off of the small fuse box and pop it open. It's a 10 amp fuse
Thanks for much!
My headlight mysteriously burnt out just the other day. It was the fuse. I didn't have a glass tube fuse so I wired in a fuse box that takes a standard automotive square style fuse. Hopefully that's your problem too!
Thad-deus Coan
09-14-2012 04:32 PM
Thad-deus Coan
Ninja 250R
09-13-2012 06:11 AM
