Handlebars for 2006 KLX250
Old 02-14-2015, 05:19 PM
fenderworks2's Avatar
Default Handlebars for 2006 KLX250
yes I have read some old posts regarding handlebars.
Is there any new info. I am looking for more motocross/offroad type bar for my klx, maybe a higher rise.
also it has to work with existing stock handlebar junk....as in horn, mirrors, electric start, throttle....you get it.
any comments would help
thanks in advance,
Old 02-14-2015, 06:06 PM
daren1093251's Avatar
I use Pro Taper High bend, I'm 5'10 and they feel wider and fit with the stock wiring. (On my 2013 though, but the bars were previously on a 91 KX80 2 stroker) They look real nice with the Pro Taper grips and the bar pad. Only issue with the bar is you get a hard time putting your key in and out the first times but all in all I reccomend you the Pro Tapers, I tipped that bike over more often then anything else and they didn't even show a slight amount of bend.
Old 02-14-2015, 11:37 PM
Go to a bike shop and check out their bars. Virtually any of them will fit the controls. If you want to be sure, measure how much space each cluster of switches, lever perch, and grip take up, then use the longest as your guide to what you need on the replacement bar.
Grab a few bends and pick the one that feels right for your wrists. If you want taller, get the high bend. You can spend from around $30 for steel bars up to well over $100 for the Pro Taper bars/clamp. You choose.
I guarantee you if I wanted to do Pro Tapers I'd spend some money on cheap steel bars to make sure I know what bend and height I want. I'd hate to screw up when it costs that much.
Old 02-15-2015, 01:58 AM
4vman1's Avatar
The stock controls are wider than most bikes, so be careful if you cut your bars down, otherwise your levers might be at a weird angle.
Old 02-15-2015, 05:39 AM
I agree with the buying cheap bars first, I order usually from rockymountain and they have some chrome Fly racing bars for 20$ and they come in CR high bend and more options. I personally adore high bends, it makes it so much more, agressive feeling. my POV though
Old 02-15-2015, 12:47 PM
MattyTracks's Avatar
I'm running PT contours, yz high bend with some eBay adapters. Happy so far.
Old 02-15-2015, 05:45 PM
thanks everybody for the suggestions.
good idea of trying cheaper bars before going big $$$
Old 02-15-2015, 06:50 PM
More of my setup, acerbis guards, pt contour, high yz, eBay spacer
Old 02-15-2015, 08:03 PM
Tacoma660's Avatar
i have a set of 2 inch risers and protaper cr high bend 7/8ths if you want that setup up for $85
Old 02-15-2015, 08:57 PM
zl PINHEAD lz's Avatar
Renthal CR High Bend
Fitted without any issues
Quick Reply: Handlebars for 2006 KLX250
