Gearing for two wheels
Old 06-02-2016, 03:06 AM
Matt88-8's Avatar
Default Gearing for two wheels
I just recently acquired a second rear wheel to use for on road. I was very happy with stock 14/42 for road, and like 13/42 off road, but wouldn't mind going slightly lower.
My question is; is it possible to get the equivalent of these ratios from the rear sprockets only and use the same chain? Or will I have to switch back and forth? Idea's?
Old 06-02-2016, 04:42 AM
GBAUTO's Avatar
Try this app-you should be able to get the answers you need. Gearing Commander: Motorcycle Speed, RPM, Chain & Sprockets Calculator
Old 06-02-2016, 11:30 AM
Tacoma660's Avatar
My street setup is 14/43 and dirt is 14/45. I think the dirt is perfect for my riding style
Old 06-02-2016, 11:40 AM
All you have to do is divide the rear sprocket tooth count by the front sprocket tooth count to find the ratio for the 13/42, then multiply it by the front tooth count you want, in this case 14 to find the closest sprocket tooth count. Round by rule of 1/2 or decide if you want to have a shade higher or shade lower gearing when picking.
42/13=3.23 (rounded for print, not rounded in next calculation for increased accuracy... like it makes some huge difference... just did it, that's all)
3.23*14=45.23 Use the 14/45.
So there's the "math" to know what to do.
You could consider going to a 15T countershaft sprocket if you are near enough to buying a new rear sprocket. Bigger wears better, less chain wrap and load distributed over more teeth.
Old 06-02-2016, 01:38 PM
cmott426's Avatar
That's not much of a change, only .4%.
if you went with a 13 front the change would be 7.1%.
Old 06-02-2016, 01:40 PM
durielk's Avatar
So now with a 42/45 rear combo, that is 3 teeth difference.
Since the chain only sits on 1/2 the sprocket, the total rear wheel difference would be 1.5 teeth.
Look at your rear wheel chain adj, can you move it forward 13/16" (1.5x5/8"pitch)?
Old 06-02-2016, 02:45 PM
Old 06-03-2016, 12:23 AM
Matt88-8's Avatar
The 07's have a snail type adjuster. But the 14 tooth sat about the 4 mark. Think there is 8 numbers.
Thanks for the math, that will help. But I also don't know what will fit the rear before I have to edit the chain guide. I would like the lowest gearing possible to use the same chain and front sprocket for both.
Old 06-03-2016, 01:39 AM
zomby woof's Avatar
Don't forget to take the tire sizes into account, street rubber being smaller.
Old 06-03-2016, 12:55 PM
MattyTracks's Avatar
I run a 47 rear sprocket with either a 13(extreme offroad), 14(good dual sport ratio), or 15 front(good on the highway) all on the same chain.
Quick Reply: Gearing for two wheels
