Front fork springs
Old 10-01-2014, 02:46 PM
Michaelb2's Avatar
Default Front fork springs
It appears as though one easy update for the KLX250s is to replace the springs. Spring selection is a function of rider weight, and installing them looks very straight forward. Question is: where to get them??
Old 10-01-2014, 03:08 PM
TNC is offline
For '09 and later models, Moto Pro seems to be a reliable source.
Old 10-01-2014, 09:13 PM
rgmr250's Avatar
Or Racetech. It seems Moto Pro and Racetech are the best sources, plus I think both have 'calculators' on their websites to calculate what the best spring for your weight/experience/riding type will be.
Old 10-01-2014, 10:50 PM
TNC is offline
Are you sure RT has optional fork springs? The reason I ask is that their site doesn't show any alternate springs. They list a recommendation as far as the weight of the spring, but they show no alternate choices...kind of strange. If you check for rear springs, they show several alternates. I'm just curious. I used RT fork springs, but I have an '06 which will use KLX300 with no problem. I know for sure that John at Moto Pro has '09 and later fork springs, with alternate weights.
Old 10-01-2014, 11:32 PM
durielk's Avatar
If you open up the forks, you will want to change the shims for the oil. That is the big fix.
Old 10-02-2014, 05:17 AM
GBAUTO's Avatar
+1^^^
If you are doing any 'enthusiastic' off roading then adding new valving makes the biggest difference in control.
Old 10-02-2014, 01:08 PM
Michaelb2's Avatar
Tell me more! I'm mostly unfamiliar with working on suspension. I watched a video on how to change the springs and it looks very straight forward. No idea about shims and valves and such.
Old 10-02-2014, 01:18 PM
TNC is offline
The damping in the KLX fork is pretty far off the mark for most riders. Going to a Moto Pro or Race Tech Gold Valve setup with a new compression piston and valve stack make a ton of difference in fork performance.
Old 10-02-2014, 01:22 PM
Michaelb2's Avatar
When I tap the front brakes, the nose dives, so I'm on board. Is changing the valves a DIY? Are there how-to videos? Links appreciated.
Old 10-02-2014, 01:32 PM
TNC is offline
A quick search of "fork revalve" yields several results like this.
KLX 250S - Kawasaki Forums[aus]-diy-shock-fork-revalve-service-42209/
Quick Reply: Front fork springs
