A few ride videos
A few ride videos
Links to a few youtube ride videos I've posted up recently.
one fairly steep trail with lots of loose rocks:
Some real bushwacking on the KLX:
Mostly bad video angles (gopro aiming down too much), but does give a different perspective:
My son riding my Goldwing, with his wife on the back, grinding the highway pegs around a corner:
He's used to riding his WR250X, which is capable of much more lean than the Goldwing - sometimes he forgets he's on the Goldwing and puts just a little too much lean in on a corner. I was following behind on my Ninja 300.
The only problem is that it was a bolt that holds the highway peg on, so it was a 'hard attached' part, rather than the footpegs, which fold up a little when you touch down, so once it's touched down, you can lift your foot a little, it's just going to scrape. He took a good 1/2" off the end of that bolt in that corner. There's a shorter bolt on there now, but not sure if the footpeg or the bolt is going to touch down first now.
Last time I was out, I was going faster, and ended up hitting about an 8-10" around rock that was completely loose - as soon as I hit it, I hit the gas to 'push' over the rock, but as soon as the front wheel touched the rock, it rolled to the side and the bike went over on its side and me and the bike went down on the side in the sharp rocks (unfortunately, the GoPro wasn't rolling for that section).
Luckily, I wear MX boots, knee/shin pads, elbow/forearm pads and a chest protector with shoulder protection (the shoulder armor had some big gouges in it after from the sharp rocks I landed on), so I had no injuries to myself, and the bike just had the handguard bent and scratched up and a gouge in the swingarm.
So, after that, I'd slowed down a little this trip, when I was in all the loose rock. Plus there's sections of loose rock (right around 2:50 in the first video), where it drops off about 100 ft to the side, so if you get off the trail, you might be spending some time trying to drag your bike back up a very steep slope or worse.
