Drilled wrong size hole in starter jet
#31
For what its worth I know splashzone is fuel compatible. I dont know about JB Weld & I would NOT consider plastic.
But I would try to just find a piece of brass round stock, find a drill that makes it a press in fit(practice on some other piece of aluminium. Then drill a hole, press in some stock, drill the jet size you want then use a center punch to lightly peen the carb material just a bit so it would hold the brass in if it works loose.
Cheers Jim
Cheers Jim
#32
Cheers Jim
Cheers Jim
#34
How about drilling out the jet completely then finding another jet that is larger then the id of the stock hole in the carb. Tap the hole in the carb so the jet can be screwed in. Solder the new jet and drill it to the .018 size and install.
Just my 2 cents.
Just my 2 cents.
#35
My money is on find a used carb. I have screwed with them. Anything can be done. I have soldered floats when they were made of thin brass. I have soldered and redrilled removable brass jets. But its a TEENY jet, way too small for my fat fingers. I think the pot metal the carb is made of will suck the heat away too fast to solder the jet AND its down in there a little. Good Luck...
I sold my stock carb and DJ kit a few weeks ago for a hunnert bucks. There must be more around here.
You may be able to learn how to use it the way it is.
David
David
#39
This discussion did get me to thinking that judicial application of heat via a soldering iron might actually allow removal of the starter jet. I wonder about that. Brewster, have you seen any sources for the starter jet itself? I haven't, but I thought maybe someone has...or any techniques for removing a starter jet.
Kawasaki offers the starter jet as a replacement part:
92059-1748
http://www.bikebandit.com/oem-parts/...023&sch=441249
