Disabling the kickstand switch..
How many of us(if any)have disabled the kickstand safety switch? I'm aware of one other person who had theirs short on them. That's a major concern too me because I often ride alone, and I'm often WAAYY out in the sticks..does Deliverance ring a bell?? [sm=helpout.gif] I'm electricity illiterate so, how do I go about removing/disabling the switch? I don't wanna break down and end up squealing like a [sm=smiley30.gif]..[sm=smiley19.gif][sm=noooo.gif] Man..I hope you guys have seen the movie..LOL
RE: Disabling the kickstand switch..
Why would you need to disable it? I've never had one fail on a bike I've owned.
However, my clutch switch is currently not working, so I can only start my bike in neutral, but that's not a big deal. I've dropped the biek a few times and managed to keep it running as I picked it back up. The bike will run on it's side for 10-15 seconds before it stalls.
ORIGINAL: motoguy128
konacoiler - Deliverence was filmed in N. Georgia, so yeah ... I know what you mean..
If it shorts out when wet, then I would assume that it's a normally open switch when the stand is in the up position. You should only need to cut the wires to the switch, seperate them, isolate each one wit helectrical tape, then coil up the extra wire and zip tie it to the frame somewhere.
If the switch needs to be closed when the stand is up, simple cut and strip the wiers, twist them together, cover them with electrical tape and and secure them to the frame.
THere's only two options. IT's a switch, it's either open or closed (On/Off). If it has 3 wires, then you would need to figure out which twi to jumper together. But I don't think it's this way.
Anyone have an electrical diagram from the service manual ot verify the switch operation?
ORIGINAL: konacoiler
and if you ever hear the phrase "you sure do have a pretty mouth" don't wait around to see what happens,just turn and run like forest gump.because that river don't go anywhwere near aintree.
motoguy128-you could do the same for your clutch safty switch.it prob also has bullet connectors at the harness so no spliceing required and gives a good weatherproof seal.
[sm=funnypostabove.gif][sm=smiley32.gif] Thanks for the input guys. I thought it was as easy as unhooking the wires and completing the circuit, but I wasn't aware of the connectors. I thought I would have to cut the wires as Motoguy said. I'll be doing this today; as we have more than our share of the wet stuff up here in the great Pacific Northwet.
Ok, I'm stupid....so I'll ask the question. What exactly does the kickstand switch do? My bike will start with the kickstand down, and also with the kickstand up. Am I missing something here? I haven't experienced its function at all. Please inform me.
