cylinder head cover removal
hi, i were trying to remove the cylinder head cover to replace the gasket (leaking..).
after removing the fuel tank and the heat protection like said in the manual, i removed all 3 bolts from the cover. next while trying to remove the cover itself i find that it just has no room to remove it.
in the right side it has 2 wires coming from the injector that are not allowing the cover to get above the cams therefore making it unable to be removed..
in the manula they state "push the right radiator and remove the cover from the right side"
what am i doing wrong :S?
