Compatible exhaust / header question
Old 10-27-2015, 06:10 PM
Narfle's Avatar
Default Compatible exhaust / header question
I've got a lot from this forum so thanks everyone. Just did the Krieger CCT and I had no idea what a difference it would make - the engine puts now instead of sounding like a blender with bolts in it.
I am doing the other mods on this site and want to slap on a KLX300 header for increased airflow but haven't been able to find out what years fit. I have an '06. Figured I'd follow that up with an aftermarket slip on which should just fit fine on the KLX300 header and mate up with my KLX250s frame right?
David
Old 10-27-2015, 06:33 PM
drm's Avatar
drm
drm is offline
header will fit but you will need a klx300 exhaust. I have both a klx300 header and an aftermarket can. I had to fab a custom bracket to mount the can to the frame.
edit...the aftermarket can only had one mounting point to the frame. I added aluminum bar stock to the stock mounts to strengthen the single mounting point.
Old 10-27-2015, 07:49 PM
Narfle's Avatar
Thanks for that. Need to know what years KLX300 headers will fit my 06 KLX250s though-
Old 10-27-2015, 10:31 PM
MaximusPrime's Avatar
Pretty sure any year will fit.
I just bought my 300 system when it came up for sale, no idea of the year, slapped it straight on a 2012.
Old 10-28-2015, 02:23 AM
drm's Avatar
drm
drm is offline
97 up
Old 10-28-2015, 01:37 PM
Klxster's Avatar
Narfle, the entire 300 system will bolt on - BUT the individual components are different.
You run into real fitment problems when you mix-and-match 300 and 250 exhaust components - so don't do it. If you want details, I can give them to you - I presently own both bikes..
In a nutshell: Use a KLX300 header - you'll be using a KLX300 slipon - stock or aftermarket. The only advantage is price(not performance) - If you can get a complete KLX300 system cheaper than a 250 slipon, you win.. The KLX300 stock silencer is easily "uncorked" by just removing the "butt plug" at the end and, uncorked, it will perform similarly to a 250 header+slipon..
Nicoleex650
06-15-2011 03:04 PM
cbr1000x
07-27-2008 07:55 AM
cbr1000x
07-25-2008 02:49 AM
kaw98zx6r
Ninja ZX-10R
07-15-2006 02:27 AM
Quick Reply: Compatible exhaust / header question
