clutch
clutch
my clutch is starting to slip when changing gears hard, in high gears and even somtimes when i let off the throttle. should i get a new oem clutch? or are there some better aftermarket ones with some stronger springs maybe?
thanks!
thanks!
Should I buy the Barnett springs?
It's pretty well documented that this happened. Since then EBC had not had problems with their springs.
This being said I just installed the EBC clutch with springs and it does seem pretty feather weight to me. I'll probably wind up switching them out for Barnett. If I had this to do angain I would have probably used KX125 frictions and a single KLX250s friction to accommodate the judda spring. More area, OEM quality. Should hold fine with stock springs.
Here's my write up on clutch options for the 250s https://www.kawasakiforums.com/forum...h-notes-41905/
dan888
03-31-2017 07:08 PM
jcbowling1985
Ninja 250R
10-19-2012 05:35 PM
