Changes to date
Changes to date
After 5 long cold months, I finally got the klx back on the road today.
Mods I completed over the winter :
- MCM
- Air injection block off plate
- FMF Q4 exhaust
- Manual cam chain tensioner
- Rear turn signal relocation (due to exhaust)
- renthal 7/8 cr high
- new grips (too short, will have to do this again)
-rad guard
- Jet kit (dynojet 132 needle, 4th clip at 1000'ASL)
- led headlamp (by far, my most worthwhile mod)
And on my to do list :
- tire bead locks
- barkbusters
- larger fuel tank
- suspension tune for my heafty 205 lbs
- Rear rack
- hardwire GPS Power (etrex 30)
- MCM
- FMF Q4 exhaust
-rad guard
- tire bead locks
- barkbusters
- larger fuel tank
- Rear rack
Instead of hardwiring your GPS why not just hook up a 12V cigarette lighter-type power port and plug into it with the power cord supplied with the GPS? A power port directly from the battery can be used to power or charge anything you care to plug in (cell phone, camera, etc.) as well as a plug-in point for a battery tender or other charger so you don't have to remove the seat to access the battery terminals.
Don't power your GPS via the USB port on the motorcycle. Get a good set of NiMH rechargeables; Powerex 2700mAh will go for a couple of days. The USB port will fail, possibly taking the whole unit out.
Geez, the universe of things to worry about is unlimited, isn't it? Now where did I leave that Zoloft?
BTW, did you hear the NiMH batteries can overheat and cause a device meltdown or worse? I don't mean to worry you, but.....
