Can't get my bike to run!
Well about month ago i blew a headgasket from overheating. it's possible the cylinder warped, obviously i can't tell, but i don't think it did either.. but anyways the bike has been set back up with new gaskets & was cleaned up, valves, adjusted & the bike jetted, but upon trying to turn it on. it starts, but HARDLY runs. unstable revs that will shut off at any idle below 1700rpm & will shut off regardless shortly after riding.
Now the only thing changed was i drilled the crankcase vent with a 1/2 in. bit.. could the fuel screw need adjusted after this?? could it be the timing wasn't set up properly? or a warped head? if i'm lucky maybe all of them? -_-
Also does the klx300 shock fit our bikes.. mine is going bad & am considering my options.
06 klx351
06 klx351
Saw the post on adv. What carb is on the bike? How long did it sit? With fuel in it?
It starts, so that is at least a beginning. Does it smoke? Missfire, backfire, all the above?
So far as idling, I can make mine idle at 1500 I believe as lowest. I have it set at I think 1700 as I don't have to fiddle with the choke so much when getting going. I could just be off on idle adjustment.
Bill blue tm33/34 it's been sitting a solid month or so, but there shouldn't have been any gas in the carb. i can spray some carb cleaner, but i have huge doubts of it being dirty to be honest since it was jetted & cleaned beforehand.
it's not been on the bike after it was brought home from being jetted. so i shook out the remaining gas that was in it, but i didn't take out any parts from it.
I used to have no issue having it idle at around 1500 before, has been erratic now though. will fluctuate about 2 or 300rpms in range up & down from time to time
ehh it will start without a choke if the rpm is above 1700 i believe. but it needs more testing to be sure. started right up with the choke though. it appears my battery is dead and won't really hold a charge, but it's been bad for awhile.. i got jumper cables so i'll just hook it up & make adjustments if it's the fuel. i think i'll recheck the timing though because that is extremely important!
By the way. Thanks for the responses everybody!
Don't really think you can adj your carb on the bench or at the shop without starting the bike. Talk to the guy that jetted it.
Kinda like sending your new slacks to the seamstress to get them hemmed, if you don't take the whole person, how does she know where to hem them?
Plus not as fun...LOL
