Blowing ignition fuse
Old 04-02-2017, 08:16 PM
mrtee's Avatar
Default Blowing ignition fuse
Hi all. After going through a puddle at speed my bike was OK but an hour later it cut out and wouldnt start. I found the ignition fuse blown and it pops every time you change it out. Im guessing there is water making a short circuit but not sure where to look?
Any advice which wires to check and how would be great, thanks
Old 04-02-2017, 10:48 PM
s10gto's Avatar
Easy way to fine a dead short it to unplug items until the short is gone. Once you have the plug that stops the short trace it to the component. You can just touch the fuse to the contacts quickly to see if it makes a heavy spark. This way you don't go through a ton of fuses.
Good luck!
Old 04-02-2017, 10:56 PM
s10gto's Avatar
Kickstand is my first guess.
Old 04-03-2017, 09:20 AM
mrtee's Avatar
Good luck!
Hi thanks for swift reply. So the fuse wont blow if you touch it on quickly but will spark if its a short circuit?
Rx78s500R
Ninja 500R
01-04-2013 01:49 PM
dsmracer
08-25-2009 08:36 PM
jstark
07-14-2008 07:35 AM
EL WASPO
09-30-2007 03:43 PM
ss_tech150
08-29-2007 10:32 PM
Quick Reply: Blowing ignition fuse
