Best way to remove countershaft sprocket?
impact-gun and a gear puller
After flattening the lock-washer, I used a 1/2" electric impact gun to spin off the nut. I did not need to lock-off the tire.
However, the sprocket itself was quite tenacious! I needed to use a small gear puller to remove the sprocket from the shaft.
I like the wood chisel idea, screwdriver and hammer kinda tears up the nut. Once away enough from nut hammering the socket to finish flattening is a great idea. I have a two foot breaker bar, kind of a long non ratcheting socket wrench. I have wife stand on rear brake lever while I stand on breaker bar and bounce...
I use a small blade screwdriver to start bending the washer, then a really big tip blade screwdriver to bend the washer flat.
I also hold the brake and use a long breaker bar. Always torque it back on, probably will slather on some anti-seize next time too... you guys are scaring me.
I really liked Honda's method of using a splined retainer in a groove that held by using a 1/8 turn that would line up two bolt holes to bolt on the retainer in locked position. Clean and quick.
